Le Deal du moment : -39%
Pack Home Cinéma Magnat Monitor : Ampli DENON ...
1190 €
 BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO
jhonguy
8 participants
BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Empty
MessageSujet: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime24/7/2010, 10:01
SALUT
VOILA LA PROBLEMATIQUE QUI SE POSE A NOMBRE D ENTRE NOUS QUI UTILISONS DES MACHINES INDUSTRIELLES DONC TRIPHASEES ACHETEES D OCCASE
STYLE TOURS FRAISEUSES PERCEUSES ETC...
ATTENTION TOUT DE MEME AUX POSTE A SOUDER LA EN GENERAL CELA NE FONCTIONNE PAS BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Kopfschuettel
IL EST POSSIBLE DE FAIRE DIFFERENTS BRANCHEMENTS AVEC DES CONDENSATEURS DE DEMARRAGE
MAIS C EST EN GENERAL UNE MAUVAISE SOLUTION
CAR CELA DECLASSE ENORMEMENT LE MOTEUR
IL CHAUFFE BEAUCOUP ET PERD SOUVENT PLUS DE LA MOITIE DE SA PUISSANCE BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  679130
LA PREMIERE CHOSE A FAIRE EST DE REGARDER LA PUISSANCE DU MOTEUR
BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Aleseu13
0.23 Cv PAR EXEMPLE SOIT 736WX0.23 = 169 Watts ET SON CABLAGE
C EST GENERALEMENT UN MOTEUR AVEC UNE BOITE A BORNES QUI PEUT ETRE
MONTE EN 220V OU 380V TRI SUIVANT COMMENT IL EST CABLE
ETOILE OU TRIANGLE
L APPAREIL QUI VA NOUS SAUVER EST CELUI CI
UN ALTIVAR DE CHEZ SCHNEIDER
BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Dsc03710
C EST UN VARIATEUR DE FREQUENCE QUI SERT HABITUELLEMENT A ASSERVIR UN MOTEUR
POUR FAIRE VARIER SA VITESSE SON ACCELERATION ET SON FREINAGE
NOUS ALLONS L UTILISER POUR UNE AUTRE DE SES CARACTERISTIQUES QUI EST LA FACULTE DE
TRANSFORMER UN RESEAU MONOPHASE EN TRIPHASE SANS PERTE DE PUISSANCE AU MOTEUR
CE QUI EST TRES INTERESSANT DANS NOTRE CAS
FAIRE TRES ATTENTION
IL EN EXISTE DES CENTAINES DE MODELES ET IL FAUT ABSOLUMENT QUE CELUI CI SOIT FAIT POUR TRANSFORMER DU MONOPHASE EN TRIPHASE
SI C EST UN MODELE TRI/TRI C EST PAS LA PEINE CELA NE FONCTIONNERA PAS BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  679130
CELUI CI DESSUS EST BIEN INDIQUE
200/240V MONO 0.37 KW SOIT 1/2Cv
C EST TOUT BON POUR NOS 0.17 KW DE NOTRE MOTEUR BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  883385
ENSUITE LE CABLAGE EST UN JEU D ENFANT
BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Dsc03910
ON BRANCHE LE MONO 220V SUR LES BORNES L1 ET L2 ET ON RACCORDE LA TERRE
C EST TRES IMPORTANT POUR LA SECURITE
PUIS ON BRANCHE LE MOTEUR TRIPHASE SUR LES BORNES U V ET W
AINSI QUE LA TERRE BIEN SUR QUI SE TROUVE IMMEDIATEMENT A COTE
COMME SUR LE SCHEMA CI DESSOUS
BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Dsc03911
AUTRE PRECISION SUR CE MODELE DE VARIATEUR IL EST INDIQUE BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  742562
TENSION DE SORTIE MAXIMALE EGALE A LA TENSION D ENTREE
SOIT POUR UN 220V MONO SORTIE MAXIMALE 220V TRIPHASE
BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Dsc03912
DONC IL ME RESTE A CABLER MON MOTEUR EN 220 V TRIPHASE POUR QUE CELA FONCTIONNE BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  883385 BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  20176
ENSUITE AVEC LA PETIT POCKET DE PROGRAMMATION IL RESTE A INDIQUER
LE REGIME MOTEUR
"MANUTENTION GENERAL OU SPECIAL"
CES APPAREILS SONT EXTREMEMENT SOPHISTIQUES EN FONCTION DES TYPES D UTILISATIONs
PROFESSIONNELLES
J OPTE POUR "GENERAL" QUI EST UN USAGE COURRANT BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  626681 SI JE PEU DIRE BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  276328
JE REGLE LA FREQUENCE DE SORTIE A 50 HZ
ET LES PARAMETRES DE SECURITE DU MOTEUR
JE VALIDE L UTILISATION DIRECTE SUR LE TABLEAU DE BORD
AVEC LES BOUTONS START STOP ET REVERSE
C EST LE PLUS SIMPLE D UTILISATION POUR MON CAS BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  883385
CONTACT ESSAI ... C EST TOUT BON
JE PEAUFINE LA RAMPE D ACCELERATION
POUR FAIRE UN DEMARRAGE EN DOUCEUR
PAR CONTRE JE VALIDE UN RAMPE DE DECELERATION RAPIDE
POUR AVOIR UN ARRET MOTEUR FRANC EN CAS DE BESOIN
POUR INFORMATION
J AI TROUVE CE MATERIEL SUR LE BON COIN POUR MOINS DE 100€ PORT COMPRIS
LE PRIX MOYEN D OCCASION DE SITUE ENTRE 100 ET 200€ SUIVANT LA PUISSANCE
NEUF CELA VAUT BEAUCOUP PLUS DE 400 A 1500€ SUIVANT LA PUISSANCE ET LES FABRICANTS
EN TOUS CAS TOUJOURS DEMANDER LES NOTICES DE L APPAREIL
AVANT DE L ACHETER
POUR VERIFIER SES CARACTERISTIQUES ET SON CABLAGE
ET S ASSURER QU IL EST INCLUS LA POCKET DE PROGRAMMATION
CAR SANS CELLE CI IMPOSSIBLE DE LE CONFIGURER BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  679130
TOUT CECI N EST PAS TRES COMPLIQUE
ET VOUS EXPLIQUE UNE SOLUTION PERFORMANTE
MAIS ATTENTION SI VOUS N ETES PAS ELECTRICIEN VOUS MEME
ET QUE VOUS AVEZ TENDANCE A FAIRE SAUTER LES PLOMBS EN BRANCHANT UNE LAMPE DE CHEVET
FAITES VOUS AIDER PAR UN VRAI ELECTRICIEN
CELA VOUS EVITERA DES DEBOIRES
DE L ARGENT GASPILLE
ET UN EVENTUEL INCENDIE ELECTRIQUE COUTEUX BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Affraid
jhonguy
jhonguy
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime24/7/2010, 10:53
c'est que du bon ca et tu trouve ca partout?
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime24/7/2010, 10:57
Sympa la plaque de cadre, PELLIZZARI, c'est une moto italienne ? connais pas ?? BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  627924 BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  683516
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime24/7/2010, 10:59
il s'agit bien d'une machine (outil) italienne BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  429241 BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  429241 BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  429241 BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  429241 BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  429241
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime24/7/2010, 11:28
SI TU TROUVES LA PUISSANCE UN POIL FAIBLE ...
ILS FONT AUSSI DES VERSIONS 160 KW BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  20176
BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Btrzuk10
FAIT JUSTE PREVENIR TON FOURNISSEUR D ENERGIE AVANT
CAR TON RESEAU RISQUE D ETRE UN PEU SOUS DIMENTIONNE BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  429241
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime24/7/2010, 11:30
Merci Yves pour ce tuto parfait, perso j'ai finalement essaye le montage condo grace à l'article sur le site Volta electricite et ca marche pour le touret et la perceuse à colonne. Mais je chasse l'Altivar sur le bon coin coin.. BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  292614 BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  883385
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime24/7/2010, 11:41
ALTIVAR EST LA MARQUE COMMERCIALE DE SCHNEIDER
C EST PAS LE SEUL FOURNISSEUR POSSIBLE
LEROY SOMER
LENZE
TOSHIBA
SIEMENS
ETC.. FONT AUSSI CE GENRE DE MATERIEL
AUTANT POUR LE TOURRET
CELA N EST PAS TRES GRAVE CAR TU TOURNES TRES VITE
ET LES EFFORTS SUR LA MEULE SONT EN GENERAL FAIBLEs ...
POUR AFFUTER UN FORET DE 5 mm BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  626681
PAR CONTRE POUR TA PERCEUSE A COLONNE
TU DOIS RISQUER DE CALER LE MOTEUR SI TU PERCES
DE GROS DIAMETRES
LE VARIATEUR DE FREQUENCE DANS CE CAS VA ETRE TRES UTILE CAR TU VAS EXPLOITER
BEAUCOUP PLUS DE POSSIBILITES
EN PREMIER
LA VARIATION DE VITESSE ... TERMINE LES REGLAGES DE COURROIES INCESSANTS
ENTRE LE FORET A CENTRER ET LE PERCAGE
AVEC UN SIMPLE POTENTIOMETRE C EST PARFAIT
ET AUSSI L INVERSEUR DE SENS DE ROTATION PAR CROISEMENT DES PHASES INTEGRE
QUI VA TE TRANSFORMER TA PERCEUSE EN TARAUDEUSE TRES FACILEMENT
IL EST MEME POSSIBLE DE MONTER UN REOSTAT AU PIED COMME SUR UNE MACHINE A COUDRE
POUR FAIRE VARIER LA VITESSE EN CONTINU BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  626681
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime24/7/2010, 17:31
Bonjour à tous,
Effectivement, le variateur est la meilleure solution, à mon taff on fait régulièrement la modif (entreprise de maintenance électromécanique + élec indus ).
Donc ceux qui on des soucis pour l'adaptation sur leur machine je pourrai peut être vous aider, envoyez moi un ptit MP.
Je peux aussi vous trouver les notices des variateurs et éventuellement vous fournir des variateur (neuf mais marques moins connue donc moins chère que du telemeca ).
Voila hésitez pas surtout si vous avez des soucis.
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime25/7/2010, 16:02
l'altivar est une solution,mais asser couteuse.vous pouvez placez deux condensateurs,un pour le démarrage et un autre pour le maintien de puissance.valeur 7mfrd par 100 watts de puissance moteur.
la société sew qui commercialise les moteurs,en fournisse d'origine ainssi concus depuis des années,et j'en utilise depuis des année dans mon job sans soucis sans échauffement .solution pas cher et de bonne qualité
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime26/7/2010, 17:56
Salut,
et le montage d'un moteur à courant continu, ça le fait non ? ils en font d'1kW pour environ 100€ en neuf.
ça peut être une solution ou il vaut mieux rester en tri et se fendre de l'achat d'un convertisseur ?
à+.
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime26/7/2010, 23:05
vas y mon yves albino albino albino
bourre la mule!
blinde la gamelle!!
pas tout pigé, mais c'est pas grave casse casse casse
j'ai seulement compris que la machine à faire des gros trous dans les carters et les chemises est opérationnelle
cafume1 cafume1 cafume1
ça sent les watt et la meule qui braise, ce truc là banana1 banana1 banana1
GAAAAAAAAAAAAAAAAAZZZZZZZZZZZZZZZZZZZZ
Very Happy albino w01
imod_13
imod_13
Masculin Nombre de messages : 34
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime30/11/2014, 22:12
Bonsoir a tous
Un système qui marche très bien et pas cher
Mon atelier est en 220 mono.
Pour faire tourner mon tour 5,5kw ma fraiseuse 4kw(moteurs 2 vitesses couplage Dahlander) et un gros compresseur 5kw , j'utilise le système moteur pilot avec trois moteur Tri 220/380 que j'ai monté en parallèle et un transfo tri  220/380.
https://sites.google.com/site/rebobinagebobinage/moteur-pilote#TOC-MOTEUR-PILOTE-monophas-230v-triphas-230v
Mes machines outils tournent depuis presque 10ans avec ce système et tout fonctionne très bien . Ça demande un peu de câblage mais rien d'impossible.
Bon rien de neuf ce système est utilisé depuis très longtemps aux USA ou on peut acheter ces convertisseurs tout fait
tchao
Un Marseillais
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime1/12/2014, 10:03
BRAVO
TRES INTERESSANTE SOLUTION ELECTROMECANIQUE QUE JE NE CONNAISSAIS PAS albino
SURTOUT POUR LES GROSSES PUISSANCE C EST NETTEMENT PLUS ECONOMIQUE QU UN GROS VARIATEUR DE FREQUENCE
SURTOUT QUE CELA PEUT SE FAIRE AVEC UN MOTEUR DE RECUP Very Happy
IL N Y A QUE LES CONDOS A ACHETER NEUFS ET SE FAIRE UN COFFRET AVEC UN CABLAGE PROPRE w01
imod_13
imod_13
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime1/12/2014, 12:36
Bonjour a tous
Et oui STOK51 j'ai tout monté avec trois moteurs de 2,2 Kw et un transfo de recup. Les condo j'en ai eu pour 30€ .Une armoire électrique des relais du câblage tout en recup et je fais tourner mes machines outils sans problème. j'ai eu des craintes pour le compresseur (ça demande beaucoup de couple au démarrage) mais non pas de problème , je sable je peint ça marche nickel.
C'est un systeme méconnu mais nettement moins cher qu'un gros variateur de puissance de 7 kw Et si j'ai besoin de plus de puissance je met une machine outil en marche pour ajouter un moteur c'est pas plus compliqué.
Ce matin pluie c'est plus ce que c'etait dans le midi
tchao
Un Marseillais
µ
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime1/12/2014, 20:27
Sympa ton montage albino Ayant un BTS éléctrotechnique, je peu te confirmer le côté méconnu, puisqu'on en a jamais parlé en cours ...
http://www.rossifumi46.fr
MessageSujet: Re: BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO    BRANCHEMENT D UNE MACHINE TRIPHASEE SUR RESEAU 220V MONO  Icon_minitime1/12/2014, 22:01
C EST SUR QUE PAR CONTRE C EST PAS TOUT A FAIT LE TOP POUR LA CONSO D ENERGIE innocent
MAIS POUR LA FACTURE  IL EST POSSIBLE QUE L ABONNEMENT MONO A PUISSANCE INSTALLEE EST MOINS SALLEE
QU UNE TETE DE LIGNE EN TRIPHASE Very Happy
» LED et ampoule classiques sur le même réseau
» Machine à pneus
» Transformation en mono amortisseur d’une Honda 500 Four
» béquille moto pour mono bras
» Mon GSX 1100 , époque Mittérand
