Pokémon EV06 : où acheter le Bundle Lot 6 Boosters Mascarade ...
 SUZURACE 2011
Léon
Pascal94
29 participants
Aller à la page : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Suivant
SUZURACE 2011  Empty
MessageSujet: SUZURACE 2011    SUZURACE 2011  Icon_minitime4/8/2010, 23:01
EHHH WALA SUZURACE 2011  775335
C EST REPARTI POUR UN TOUR
DE PLUS EN PLUS FORT
2010 VOUS AVEC VU ET ENTENDU SUZURACE 2011  753587 CELLE CI SUR LES CIRCUITS SUZURACE 2011  276328
SUZURACE 2011  0_201027
UN TOUT PETIT 998CC YOSHIMURA TRES PRECIEUX
DANS UN CADRE PEM D EPOQUE
ENFIN FAUT BIEN SE RAPPELER QU AU DEBUT CELA RESSEMBLAIT A CA ... SUZURACE 2011  Affraid
IL Y A PILE UN AN SUZURACE 2011  626681
SUZURACE 2011  Imgp3310
ET TOUT LE RESTE HOME MADE ....
ON PASSE LE CAP SUZURACE 2011  20176
CETTE FOIS CI CONSTRUCTION TOTALE DE TENEZ VOUS BIEN
2 MACHINES NEUVES
TOUT CONSTRUIT DE ZERO
LES CADRES LES BRAS OSCILLANTS ET LES BERLINGUES
QUAND JE DIS CONTRUITS ON NE PARLE PAS DE BRICOLAGES
DE RESTORATIONS OU D ADAPTATIONS
C EST TOUT FAITS DANS LES REGLES COMME D AB
ET 1000% CONFORMES AU REGLEMENTS LES PLUS TATILLONS SUZURACE 2011  883385
LES GEOMETRIES LES SOLUTIONS TECHNIQUES
ET LES BASES MECANIQUES ANTERIEURES A 1980
BON LE POINT DE DEPART
CETTE SEMAINE J AI ATTAQUE LE NERF DE LA GUERRE
LES BROUZOUFS SUZURACE 2011  615257
CA VA ENCORE MIAULER DANS LES BOIS DES ARDENNES
MAIS CE COUP CI ON SE RETIENT PLUS
ON A PAS DU BERLINGUE HISTORIQUE A PRENDRE GRAND SOIN CAR UNIQUE
ET FAISANT PARTIE DU PATRIMOINE MONDIAL DE L HUMANITE MOTOCYCLISTE
ON EST DANS DE LA BASE
DU VULGUS PECUM
DU TOUT VENANT
DU AU POIDS A LA CASSE DU COIN
DU A DEBARASSER SOUS PEINE DE FONDERIE
DE LA BALADURETTE A LA REFORME
DE LA PRIME A LA CASSE
DU BORLLOO A RECYCLE
ET GROS ON LUI TAILLE DANS LE VIF SANS AUCUNE RETENUE
ON LUI COLLE DES BOURRINS A EN RACOURCIR LES BIELLES
ON VA CHERCHER LA LIMITE ET ON SAIT QU ELLE EST TRES TRES LOIN
ON VA SE MARRER SUZURACE 2011  753587
ON A GEF EN POINT DE MIRE SUZURACE 2011  626681
SAVACHIER SUZURACE 2011  728917
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime4/8/2010, 23:04
Des cadres poutre ?
SUZURACE 2011  Empty
LE BLOC OPERATOIRE A FONCTIONNE A PLEIN REGIME
VOILA LES CADAVRES
J AI COMMENCE A RACLER L OS ..
SUZURACE 2011  Suzura10
LE MODELE DU MAITRE A PORTEE DE MAIN POUR PAS S EGARRER
DIEU POPY VEILLE SUR SES OUAILLES SUZURACE 2011  26876
SUZURACE 2011  Suzura11
ET TOUTES LES PETITES FAIBLESSES CONSTATEES EN COURSE CETTE ANNEE SERONT
BIEN SUR CORRIGEES
SUZURACE 2011  Suzura12
LE COUVRE CULASSE PAR EXEMPLE PAR UN MODELE A 4 VIS RENFORCE
CEUX QUI ETAIENT A SPA M ONT COMPRIS SUZURACE 2011  276328
ON VOIT D AILLEURS BIEN LA SOUDURE DE LUC QUI A PARFAITEMENT TENU SUZURACE 2011  883385
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime4/8/2010, 23:06
les affaires reprennent SUZURACE 2011  276328 SUZURACE 2011  276328 SUZURACE 2011  276328
SUZURACE 2011  Empty
MessageSujet: re suzurace2011   SUZURACE 2011  Icon_minitime4/8/2010, 23:08
t'a raison persiste dans les suz
jme doute de ce que tu prépare SUZURACE 2011  626681
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime4/8/2010, 23:29
POUR BROUILLER UN PEU LES PISTES ....
CHERCHEZ L INTRU SUZURACE 2011  775335
SUZURACE 2011  Suzura13
TROP FASTOCHE SUZURACE 2011  429241 SUZURACE 2011  429241 SUZURACE 2011  429241
BON ALLER AU PLUME DEMAIN YA MECANIQUE SUZURACE 2011  20176 SUITE
A SUIVRE
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime4/8/2010, 23:32
albino albino albino
olé, olé
ça y est , albino albino
remettez nous ça patron albino
one again, ouane egaine, bissetouflaille Very Happy
vous deviez un peu vous en douter, nan ? casse casse
nan ??? vous m'avez cru quand je vous avais annoncé avoir viré les goujons du carter pour nettoyer les filetages ???
casse casse casse
à vrai dire, on ne sait pas encore exactement comment ça va se presenter ....
ce qui est sur, c'est qu'il y a deux moulbifs en pièce et qu'on va pas les remonter "orig" innocent innocent innocent
déjà, pour commencer, les bloc cylindre ne sont pas frappés 1074 ..... mais 1135 ... et c'est pas pour faire l'économie d'un réalésage ....
pour le reste, on vous dira (tout ?) en allant ....
pour les cadres, non, non, c'est pas du poutre....
Maitre braiseur- françois ayant validé le PEM double berceau monoamortisseur latéral,... "un vrai bonheur" ..."y s'passe rien nulle part " "meme dans la foret, vite, c'est les coucougnettes qui manquent, mais pas le cadre qui bronche" .... validé le PEM, donc, eh ben ......
quand tu gagnes, tu r'joues , nan ?
on lui a donc fait faire des petits, à l'enfant de Mr MORENA (des jumeaux, tant qu'a faire ...)
les ébauches des berceaux en 25 CD4S sont d'équerre .... Luiggi a pour mission de les finir en copiant l'original
avec les GAZ, on va optimiser un peu tout pour avoir le max de pièces en commun
next year, eux et nous serons le meme team, avec exactement les memes bécanes et vraissemblablement des couleurs inversées
ça devrait avoir de la gueule un truc comme ça
(une des motos est pour eux) w01
GAAAAAAZZZZZZZZZZZZZZ
Thieryyyyyyyyyyyyyyyyyyyy Very Happy Very Happy Very Happy Very Happy Very Happy regarde bien la génèse des machins qui vont ...... t'abeiller dans les oreilles !!! casse casse casse
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime4/8/2010, 23:38
casse casse casse casse casse
et les chemises ont été sorties pour bien nettoyer l'alu derrière !!!!!
si, si Very Happy Very Happy Very Happy
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime4/8/2010, 23:41
Bon je vais me coucher, trop forts les rémois et leurs complices SUZURACE 2011  883385
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime4/8/2010, 23:42
A SUIVRE
J' ai trouvé l' intru: Le pneu a tétines... casse casse casse
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime5/8/2010, 21:50
TROP FORT FLY SUZURACE 2011  26876
C ETAIT EFFECTIVEMENT LA MEILLEURE REPONSE QUE J ATENDAIS ... SUZURACE 2011  883385
LE TRIPLE ETAIT JUSTE LA POUR BROUILLER LES PISTES SUZURACE 2011  429241 SUZURACE 2011  429241 SUZURACE 2011  429241
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime5/8/2010, 21:55
BON SUITE DE L AUTOPSIE DU MONSTRE
LE MAL AVAIT PARFAITEMENT ETE IDENTIFIE EN COURSE A SPA
ET ON A BIEN FAIT DE NE PAS INSISTER
C EST LE MOINDRE MAL RIEN N EST ABIME
SUR CE TRES BEAU MOTEUR
JUSTE UN JOINT DE CULASSE PAS ASSEZ RESISTANT
LE PROCHAIN SERA EN CUIVRE
CELUI CI A FAIT ENVIRON UNE VINGTAINE D HEURE DE CIRCUIT
C ETAIT TROP LUI DEMANDER
UN PETIT SURFACAGE DE CULASSE ET DU BLOC CYLINDRE
HISTOIRE DE PARTIR SANS APPREHENSION
CA C EST DU JOINT DE CULASSE PETE SUZURACE 2011  Icon_pale
"ALLOOOO GARAGE GAUDIN J ECOUTE " SUZURACE 2011  429241 SUZURACE 2011  429241 SUZURACE 2011  429241
SUZURACE 2011  Suzura14
SUZURACE 2011  Empty
MessageSujet: re suzurace 2011   SUZURACE 2011  Icon_minitime5/8/2010, 21:56
les PEM c'est bien SUZURACE 2011  883385
copieur SUZURACE 2011  276328
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime5/8/2010, 22:21
ON COPIE PAS .....
ON PRESERVE LE PATRIMOINE APRES L AVOIR SAUVE DE LA BIFFE SUZURACE 2011  626681
C EST TRES DIFFERENT SUZURACE 2011  615257 SUZURACE 2011  276328
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime5/8/2010, 22:32
ah ben oui il a bien pété ton joint de culasse
ca a du commencé quand elle c est mise a fumer grave par le reniflard
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime6/8/2010, 00:39
LE PASSAGE DANS LE PUIT DE CHAINE DE DISTRIBUTION FAISAIT QUE CELA FUMAIT
MAIS NE CONSOMMAIT PAS D HUILE
ENSUITE CELA NE S EST BIEN SUR PAS ARRANGE ....
ENFIN RIEN DE BIEN GRAVE SUZURACE 2011  276328 SUZURACE 2011  20176
ET FACILEMENT REPARABLE
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime6/8/2010, 07:44
EX - CE - LENT SUZURACE 2011  681916
vite la suite . SUZURACE 2011  883385
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime6/8/2010, 08:38
encore du rêve a suivre
bon courage pour la suite
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime6/8/2010, 09:14
bon ....
ben c'est pas bien méchant , ça w01
mon petit doigt me dit que l'heure de la retraite n'a pas encore sonné Very Happy
on va finir d'ausculter la merveille ... il y a un petit roulement qui se barre .... ça doit pas être terrible non plus ...
berlingue rachoupillé, partie-cycle encore optimisée .... ça sent encore le bonheur, tout ça banana1 banana1 banana1
ça va ouiner et l'abeille va encore sonoriser le bout droit casse
tiens, je vous en remets un petit coup ..... je ne m'en lasse pas ! albino
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime6/8/2010, 09:32
ET ENCORE LA ELLE ETAIT EN MODE VALIDATION REMISE EN ROUTE
APRES 25 ANS DE SOMMEIL SUZURACE 2011  626681
A SPA C ETAIT ENCORE UN AUTRE NIVEAU
DANS LA DESCENTE DES STANDS AVANT LE RAIDILLON SUZURACE 2011  926392 SUZURACE 2011  926392
J EN AI LES TYMPANS QUI FRETILLENT ENCORE SUZURACE 2011  276328
MEME PAS BESOIN DE LEVER LES YEUX JE SAVAIS QU ELLE ETAIT PASSEE A L OREILLE SUZURACE 2011  546167
LA MONTEE EN REGIME CARACTERISTIQUE ET LE MIAULEMENT DE LA PETITE CYLINDREE
INCOMPARABLE SUZURACE 2011  615257
ON VA L ENTENDRE A NOUVEAU EN VERSION HYPER LIGHT SUZURACE 2011  626681 SUZURACE 2011  775335
1CV/1KG SUZURACE 2011  79620
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime6/8/2010, 10:09
Un beau sujet que vous nous préparez là + le fait de monter une structure de 2 machines c'est parfait.
+ S'instruire en samuzant SUZURACE 2011  26876 .
Pour le joint de culasse, le Cu dont tu parles, c'est en 3 couches ou en 1 épaisseur ?
Je revois encore les english qui posaient un bout de fil de FER sur le joint de culasse(à l'endroit le plus faible) avant de refermer... SUZURACE 2011  Affraid .
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime7/8/2010, 18:48
ça s'annonce plutôt bien , nan ???
casse casse casse
l'abeille .... LE RETOUR !!! Very Happy
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190427169937&viewitem=&sspagename=STRK%3AMEWNX%3AIT#ht_500wt_1182
GAAAAAAAAZZZZZZZZZ
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime7/8/2010, 21:13
c'est toi qui l'a acheté , merde , c'est moi qui avait la mise à 10 $ , enfoiré .va ....nikitalilly etc...
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime7/8/2010, 21:14
d'ailleurs , c'est pour un 1150 cc .xwala . SUZURACE 2011  211176
SUZURACE 2011  Empty
MessageSujet: Re: SUZURACE 2011    SUZURACE 2011  Icon_minitime7/8/2010, 21:29
tof01 tof01 tof01 angel angel angel banana1 banana1 banana1
Sad Sad Sad Sad Sad Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad
SUZURACE 2011  817987
SUZURACE 2011  Empty
SUZURACE 2011
Page 1 sur 10Aller à la page : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Suivant
» bol 2011
» photos du boc 2011
» BOC 2011 LA COURSE
» vma 2011 nogaro
» Le brelon #41 au BOC 2011
FORUM DES MOTOS SPÉCIALES :: PISTE :: LES TEAMS du FORUM-
