POUR PRECISER ET COMPLETER ENCORE CE POST
ON EST BIEN D ACCORD ON PARLE POUR L HUILE DES MOTEURS 4T
LES REFROIDISSEMENTS LIQUIDES ET LES 2T C EST UN PEU DIFFERENT ...
LES INFORMATIONS DONNEES PAR UN THERMOMETRE ET UN MANOMETRE POUR L HUILE SONT COMPLEMENTAIRES
DEPENDENT DE CE QUE L ON CHERCHE
ET DE LA CONSTRUCTION DU MOTEUR
1/ LA TEMPERATURE D HUILE PRISE AVEC UNE SONDE DANS LA BACHE A HUILE POUR LES MOTEURS A CARTERS SECS COMME LES 750 FOUR HONDA SOHC
OU DANS LE CARTER INFERIEUR POUR LES MOTEUR TYPE Z900 Z 1000 GS 1000 OU GSX 1100
EST UNE DONNEE TRES INTERESSANTE POUR VOIR LA MONTEE EN TEMPERATURE DU MOTEUR ET CONSERVER LES PERFORMANCES DE L HUILE OPTIMALES
C EST AUSSI IMPORTANT PAR LE BAS QUE PAR LE HAUT
EXEMPLE :
SI IL FAIT 6°C A SPA ET QUE L HUILE MOTEUR NE MONTE PAS A PLUS DE 50° IL EST URGENT DE DIMINUER LA SURFACE DU RADIATEUR D HUILE
AVEC DU SCOTCH AMERICAIN
CELA PERMET DE CONNAITRE A PARTIR DE QUEL MOMENT ON PEUT UTILISER LE MOTEUR DANS DE BONNES CONDITIONS
INVERSEMENT A MAGNY COURS EN JUILLET IL FAIT 35°C ET 45°C SUR LE TARMAC L HUILE MONTE A 120°C
ET A L ARRIVEE DANS LES STAND ON EST A PLUS DE 130°C
APRES L ARRET AUX STANDS IL Y A GRAND DANGER POUR LE HAUT MOTEUR EN PARTICULIER
LE RADIATEUR EST SOUS DIMENTIONNE LE REFROIDISSEMENT MOTEUR EST INSUFFISANT CARENAGE TROP FERME OU MAL ETUDIE DONC A REVOIR
2/LA PRESSION D HUILE EST UNE DONNEE PARTICULIEREMENT IMPORTANTE POUR LES MOTEURS A COUSSINETS EQUIPES DE POMPES TROCHOIDALES
PAR EXEMPLE
LES MOTEURS HONDA EN PARTICULIER OU LES Z 650 KAWA
ELLE PERMET DE FAIRE LE FILM DE GLISSEMENT ENTRE LE COUSSINET MINCE ET LE VILO
DES LA RUPTURE DE CE FILM D HUILE IL Y A DESTRUCTION IMMEDIATE DU REVETEMENT ET IL FOND D OU L ANCIENNE EXPRESSION COULER UN BIELLE
UNE PRESSION D HUILE EN BAISSE EST DONC UN SIGNE AVANT COUREUR DE PROBLEMES MOTEUR GRAVES
SOIT LA VISCOSITE DE L HUILE EST INSUFFISANTE DU FAIT D UNE SURCHAUFFE OU D UNE HUILE NON ADAPTEE
SOIT LE JEU D ASSEMBLAGE DU MOTEUR EST MAUVAIS OU TROP USE ET LA PRESSION D HUILE NE REUSSI PLUS A MONTER CORRECTEMENT
COUSSINETS USES PORTEES DE VILO MARQUEES POMPE A HUILE EN MAUVAIS ETAT
CREPINE D HUILE COLMATEE...
ATTENTION AUSSI A REGARDER A QUEL ENDROIT CETTE PRISE DE PRESSION EST CONNECTEE
SUR LES MOTEURS A VILO SUR ROULEMENTS LA PRESSION D HUILE DANS LE BAS MOTEUR NE DONNE PAS D INDICATION INTERESSANTE
EN PARTICULIER SUR LES MACHINES EQUIPEES D ANTIQUES POMPES A ENGRENAGES DONT LA PRESSION DE SORTIE EST TRES FAIBLE
ON PARLE D AILLEUR DANS CE CAS PLUS D UN DEBIT QUE D UNE REELLE PRESSION
PAR CONTRE CELLE SUR LE HAUT MOTEUR EST PLUS INTERESSANTE
POUR LES Z KAWA LES AAC TOURNENT SUR DES COUSSINETS ET SUR LES 1100 GSX SUZ C EST DIRECTEMENT DANS L ALU DE LA CULASSE
UNE PRESSION D HUILE INEXISTANTE SUR UN HAUT DE MOTEUR DE 1100 GSX C EST DESTRUCTION DE LA CULASSE ET POUBELLE
CELA S EST DEJA VU AVEC DES HUILES NON ADAPTEES A CES MOTEURS
EXEMPLE SUR UN ZX 1100 KAWA
UN SUPERBE HUILE DE FORMULE 1 A PRIX DEMENTIEL TYPE 0W60 EST CATASTROPHIQUE
LA POMPE A HUILE A ENGRENAGES N EST ABSOLUMENT PAS CONSTRUITE POUR DES HUILES AUSSI FLUIDES
EN RESUME
SI VOUS NE VOULEZ PAS UN TABLEAU DE BORD D AIRBUS ET N EN METTRE QU UN
POUR UN MOTEUR A COUSSINET PRIVILEGIER PLUTOT UN MANOMETRE
POUR UN MOTEUR A VILO SUR ROULEMENTS UNE TEMPERATURE D HUILE EST PLUS INTERESSANTE
WALA MON EXPERIENCE ET CE QUE J EN PENSE
ENSUITE IL Y A TOUJOURS DES CAS PARTICULIERS POUR UN 350 RDLC OU TZ EVIDEMMENT ON VA PARLER DE TEMPERATURE D EAU
MAIS COMME JE L AI DIT AU DEBUT JE ME SUIS LIMITE AUX MOTEURS 4T A REFRODISSEMENT PAR AIR
