Tablette 11″ Xiaomi- Mi Pad 6 global version (coupon + code promo)
224.97 €
 GPZ 750 AMA 'Rob Muzzy" made in japan
11 participants
GPZ 750  AMA  'Rob Muzzy"   made in japan Empty
MessageSujet: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 08:57
GPZ 750  AMA  'Rob Muzzy"   made in japan Gpz_7511
GPZ 750  AMA  'Rob Muzzy"   made in japan Gpz_7512
GPZ 750  AMA  'Rob Muzzy"   made in japan Gpz_7513
GPZ 750  AMA  'Rob Muzzy"   made in japan Gpz_7514
GPZ 750  AMA  'Rob Muzzy"   made in japan Gpz_7515
GPZ 750  AMA  'Rob Muzzy"   made in japan Gpz_7516
GPZ 750  AMA  'Rob Muzzy"   made in japan Gpz_7517
Désolé pas de traduction, mais des chiffres sont visibles
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 09:20
C EST UNE TRES BELLE REPLIQUE MAIS IL EN MANQUE ENCORE UN PEU ...
GPZ 750  AMA  'Rob Muzzy"   made in japan Kawatu10
GPZ 750  AMA  'Rob Muzzy"   made in japan Kep2110
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 09:30
940cc dans le GPZ ... ça devait causer un peu; en + du reste ...
Un bloc spécial pour les pistons ?? et des pistons Kawa ?? le carter réalésé ?? tu as des infos là dessus ???
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 09:39
j adorrrrrre
a part l attache rapide
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 10:51
JE NE SAIS PAS MAIS UNE CHOSE EST SURE LES PREMIERS MONTAGE 940 CC SE SONT FAITS SUR UNE BASE 650 EN 1978 PAR MIKE SPENCER
ET IL RESTAIT TELLEMENT PEU DE PLACE QUE LA POMPE A HUILE EST PASSEE A L EXTERIEUR DU BLOC MOTEUR cafume1
ENSUITE A PARTIR DE 82 LA CYLINDREE EST LIMITE A 750 CC
DONC FIN DE LA RECREATION ET DU BRICOLAGE angel
ARRIVEE DES MOTEURS D USINE DIRECT DU JAPON Cool !!!
EMBRAYAGE A SEC Sad
DOUBLE ALLUMAGE BOUGIES DE 10 MM PAR MAGNETO
GROSSES SOUPAPES 31 ET 35 MM
CONDUITS AGRANDIS ET REDRESSES
RAMPE CR 31 OU 33 SUIVANT LES CIRCUITS
AAC DE 9.8 DE LEVEE ET 300° D OUVERTURE
DANS UNE CULASSE A FONDERIE SPECIALE MOULEE AU SABLE innocent
C EST AVEC CET OUTIL QUE RAINEY A TOUT GAGNE EN 1983
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 10:56
Yves, L'embrayage à sec sur le turbo c'est ton oeuvre ou t'en n'es pas encore là??? innocent
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 11:00
PHOTO DU KIT DISPONIBLE AU JAPON ....
JE PREFERE LES SOLUTIONS MAISON POUR DES RAISONS ECONOMIQUES EVIDENTES pacontent01
C EST EN ROUTE POUR LES BASES Z 900 innocent
JE VOUS TIENDRAIS AU COURRANT Very Happy
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 11:15
Merci pour les photos et les explications yves albino
A+ Salut zdrag
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 11:19
innocent ROAD t'es en vacance ou quoi :Tudor ,meme pas une reaction
il a un malaise albino albino albino
Salut :Tusors
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 11:50
albino Carrément excellent !!!
Merci PIERRE, grace à toi je crois bien avoir trouvé la solution à mon probléme innocent
En tous cas MERCI pour toutes ces tofs, y'a de quoi s' inspirer ...
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 12:19
Super Jolie , belles pièces ,
juste la fourche fait toute petite . petite ...mais je préfère aux inversées adaptées qui dénaturent trop le style de la moto . albino
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 12:26
Yves, effectivement c'est ce qui est détaillé dans la revue jap d'où sont tirées ces photos... albino albino
Dommage que chez MUZZY, il 'y ait plus d'archives bom
Il ne reste pas beaucoup de place pour la soupape de 35mm
SuzieYosh , de quel pb tu parles ?? la garde au sol ??
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 12:48
vraiment top!! albino albino
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 13:04
sauf peut etre les poignees passager qui ont ete conservees innocent
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 13:18
et les clicos , le phare , les garde boue, les rétros
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 15:16
C EST SANS DOUTE LA CYNEMATIQUE DE LA SUSPENSION A L ARRIERE
C EST LA DESSUS QU ILS ONT LE PLUS BOSSE
LE BASCULEURS USINE DANS LA MASSE AVEC LES 2 TIRANDS REGLABLES AVEC LES ROTULES UNIBAL ET VIS TITANE ...
AMORTISSEUR FOX A AIR OU WP
L ARRIERE EST RELEVE DE 32 MM EXACTEMENT
POUR L AVANT MONTAGE COMPLET DE LA FOURCHE ET DES FREINS DE 1000 S1
LA VERSION COURSE EN SERIE LIMITE DE LA 1000 ELR
ROUES DYMAG MAGNESIUM
AVANT 2.75X18
ARRIERE 4X18
DISQUE ARRIERE DE 247 MM DE DIAMETRE
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 15:22
sur la vraie de Rayney & Cooley le bras était celui (similaire) des 550 GPZ, système différent de l'origine
GPZ 750  AMA  'Rob Muzzy"   made in japan Cooley10
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 15:25
PIERRE C EST SIMPLEMENT LE HAUBANAGE RENFORT QUI EST PAR LE DESSUS
C EST UN BRAS DE 750 ZX D ORIGINE MODIFIE
LE SYSTEME RESTE AVEC L AMORTISSEUR VERTICAL AVEC BASCULEUR PROGRESSIF
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 15:31
merci de l'info,
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 17:36
MAGNIFIQUE aime aime aime aime aime aime aime aime aime aime aime aime aime aime aime aime
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 17:40
Ca donne des idees pour l'hiver.... innocent albino
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 17:52
POURQUOI ATTENDRE L HIVER casse casse casse
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime24/7/2009, 19:36
casse casse
C'est déjà commencé
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime25/7/2009, 09:19
OUI OUI Bien sûr,
Et l'assiette aussi puisque dans le cas de la ZX les deux sont directement liés w01
MessageSujet: Re: GPZ 750 AMA 'Rob Muzzy" made in japan   GPZ 750  AMA  'Rob Muzzy"   made in japan Icon_minitime25/7/2009, 09:33
... C EST SANS DOUTE LA CYNEMATIQUE DE LA SUSPENSION A L ARRIERE
L ARRIERE EST RELEVE DE 32 MM EXACTEMENT ...
C'est EXACTEMENT là que je dois trouver une solution,
Car un premier roulage Lundi dernier à Carole w01 (moto strictement d'origine, juste la béquille centrale otée) a permis de mettre en évidence le principal défaut de la moto:
Moto longue, trop sur l' AR = maniabilité en berne donc trés physique.(en plus du poids)
Je me penche sur le probléme dés que je reçois l' ensemble amortisseur/fourche innocent
... Mais à coup sûr, y'a moyen de faire quelque chose de bien albino
» Made in "CORKI Racing"
» ELR by MUZZY
» == Kawasaki 1000 "LAWSON Réplica" 1981
» Pour ceux qui aime le "Spécial" moderne...
» Honda CB 750 répliqua Daytona " Tonton Boum 57"
